Vision PM4230
Discussion in 'Plasma TVs' started by scottc, Aug 9, 2004.
  1. scottc
    scottc
    I have an offer on a Vision PM 4230 and was wondering if you guys had heard or seen one.
    It is a very good offer and this is the only reason I am considering it but don't want to buy it if it's not good.
    Can anyone help??
    Here is a link
    http://www.vision-displays.com/
  2. Mat-Moo
    Mat-Moo
    Jan 7, 2003
    766
    +6
  3. SuperSportBilly
    SuperSportBilly
    May 18, 2004
    2,083
    83
    +390
    Anybody seen this - a friend is looking for a 42" plasma
    The specs look fine Contrast ratio of 4000:1 and decent brightness.
    But - if something seems too good to be true it usually is.
    Any views ?
  4. Dextur
    Dextur
    Aug 30, 2004
    10,189
    +1,749
    contrast is 3000:1 according to simply , very few sets , Panny usually have 4000:1 , the brightness is quite low at 500 IMO
    Also I htink this is just a panel not a TV, are you aware of that? Ie no tuner as far as I can see, but I could be wrong, you would need to get a freeview or Sky to watch terrestial channels.
    £1,300 though , damm cheap. No idea about quality of picture though
  5. Dextur
    Dextur
    Aug 30, 2004
    10,189
    +1,749
  6. Johnnypanic
    Johnnypanic
    Aug 4, 2004
    201
    +16
  7. Dextur
    Dextur
    Aug 30, 2004
    10,189
    +1,749
    Well not entirely sure I would classify that as a review, more an end user comment at best. 'It's good' barely qualifies our reviewer friend as PQ specialist.
    I would do a search on here, that shows you comments from many users who were unhappy with it, but at the end of the day only trying it for yourself is the answer.
    Again, I state for the record it's not a TV but a panel, so you need either a tuner box or freeview/sky to watch terrestial on it, also I dont' think speakers are included you will need a home cinema set up.
  8. SuperSportBilly
    SuperSportBilly
    May 18, 2004
    2,083
    83
    +390
    Yes sorry - contrast ratio is 3000:1 and brighness is 1300 cdm.
    CR is same as my Panny 37" !
    Not a problem that it is a panel only will be plugged into Sky.
    Anybody with first hand experience ?
  9. Damian1978
    Damian1978
    Jul 15, 2000
    4,487
    107
    Fleetwood, Lancashire
    +264
    I'd be interested in some first hand experience of this set as Maplin do it for £1500 with interest free credit.
    It actually looked pretty decent displaying a DVD. If I pop down again I may ask for a play with it as I'm not sure how it was all connected up (plus its very bright in the shop).
  10. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    One thing i have found is that cheap plasmas look pretty good until you see them next to a better unit, Pio/Panny etc then they look crap!!! £1299 for a42" Plasma is very very cheap, second cheapest screen i have seen....................
