Vision pm4230 contact info.
Discussion in 'Plasma TVs Forum' started by WhoYa, Feb 26, 2005.
  1. WhoYa
    WhoYa
    Have had a vision pm4230 for about 9 months now with no problems.
    It has however just delevoped a fault where there is about a 6" vertical black band on the left hand side of the screen. I am assuming that the driver board for that strip of the screen has died.
    I have been trying to find the contact info for the company but have had no luck, does anyone have a contact no or address as there website seems to be down.
  2. Ryan Keen
    Ryan Keen
    did you have any luck?, mine has done the same thing on the right hand side!!! and i cant find the warrenty book and place i got it from wont help!!
  3. ukdan
    ukdan
    Feb 16, 2005
    1,136
    swindon
    +85
    where did you get it from and how old is it?
    surely if its still under warrenty its up to the retailer to sort it out?
  4. Ryan Keen
    Ryan Keen
    its only 3months old... the shop that sold it said it comes with 1yr on site warrenty, and the number should be on the warrenty pack - that i can't find!
  5. ukdan
    ukdan
    Feb 16, 2005
    1,136
    swindon
    +85
    Then if that was me i would ask the store for the number. if they refuse to give it out then ask for a refund. You will be in your rights to do so.
  6. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    The shop should help you. If they don't want to, tell them your rights, perhaps they have not heard?
