Vision PM-4230 Plasma Screen
Discussion in 'Plasma TVs Forum' started by Genesis, Aug 11, 2004.
  1. Genesis
    Genesis
    Aug 11, 2004
    196
    +3
    has anyone seen a review on this model, or maybe even own one. I am looking for some more infomation.
    Thanks :lease:
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    Erm try a search... Have you bought one?
  3. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    Same screen as the dreaded techwood. Try searching for that too.
  4. jaxc
    jaxc
    dont buy one, I have had mine for 18 months and its blown already, and out of warranty. anyone know a good plasma engineer? :mad:
  5. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    Mastercare? (not very good but should be able to sort it)
  6. Elerimai
    Elerimai
    Hi Everybody,
    I have a Vision PM-4230 that has gone faulty, i have located the fault but Vision will not sell me the component so i am looking for the " X- Sustain board" from inside the unit, so if anybody out there has a damaged Vision plasma screen i would like to buy this board from you, if you have it for sale
    Hope you guys can help.
