Vision Plus DTV problem
Discussion in 'Home Cinema Buying & Building' started by Gerry7, May 6, 2007.
  1. Gerry7
    Gerry7
    Apr 25, 2007
    4
    In May 2005 I bought a Tiny computer which is equipped with a Vision Plus DTV card. At the time I lived in rented accommodation and had no decent TV aerial. I now have a good aerial but cannot get any picture. There are icons on the DTV display for satellite and aerial signal strength. The aerial signal is showing at about two per cent.
    Tiny , of course, went bust shortly afterwards so I can't get any advice from them.
    Should I be able to get TV programmes via my aerial with this card? If so how? If not do I get a different card? Which one is the best value? Is it difficult to install?
