vision plasma
Discussion in 'Plasma TVs Forum' started by Steve.EX, Feb 18, 2002.
  1. Steve.EX
    Steve.EX
    Oct 17, 2001
    3,161
    68
    +69
    Does anyone have any thoughts/experience on the Vision range of plasma's, a friend has been offered a new 42" for £3175 (mail oreder) but finding info on both the manufacturer(?) and it's products has not been "easy". your thoughts are gratefully appreciated.
    SteveEX
  2. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    26,891
    The Borders
    +3,117
    Steve
    Other than seeing a few adds in the trade magazines we get I don't know much about this product line-up or the company behind it - I will try to do a bit of homework and report back.
    Regards
    Joe
    PS Panasonic TH-42PWD4EX in Charcoal still wins my vote
  3. Steve.EX
    Steve.EX
    Oct 17, 2001
    3,161
    68
    +69
    much appreciated.
  4. Cool-hand
    Cool-hand
    Jan 5, 2002
    2,116
    Portsmouth / Middle East
    +77
    I can comment on this screen, as a PDP owner now I previously spent months going up and down the country looking for the right set.
    The Vision set suffers from colour banding which is never more obvious than when a sky scene is playing or dark scenes with candels glowing (giving a kind of rainbow effect in the graduation of colours) I.e. light blue to dark blue. This I imagine is why the set is now floating around the 3k mark (old generation electronics inside) sorry, im sure thats not what you wanted to hear.
    Unfortuneatly the Daewoo is also the same (which is also around the same price bracket). If your gonna spend that much on a PDP then go the extra 1k and play it safe and go for a Panasonic or Fujitsu after all it's about picture quality at the end of the day isn't it!
    One thing you absolutey must do is demo any screen before you shell' out your dosh. Harrods of London has over 15 plasma's on display (all the ones that are worth their salt are there)!
    Good luck
  5. Steve.EX
    Steve.EX
    Oct 17, 2001
    3,161
    68
    +69
    I guess you read that Gav! speak to you later mate.
    Many thanks for the contributions - All.
    SteveEX
