vision mixers
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by DJSWITCH, Sep 5, 2004.
  1. DJSWITCH
    DJSWITCH
    Hi there,
    Does anyone know where i can get a low cost vision mixer in the uk, just basicly for mixing in live images being taken from 2 video cameras.
    i have seem an edimol mixer that looks half decent but i want something cheaper realy.
    thanks for your help
  2. Roy Mallard
    Roy Mallard
    what type of cameras are you using?. For effective vision mixing you'll need a genlock and cameras that can be genlocked, otherwise you will have really dodgy cuts, transitions etc.
    does it have to be a live mix?, fianl cut/premiere/avid etc will let you lay down two (or as many as you want really) video tracks and let you cut or transition between them.
    try H.Prestons for second hand mixers
