Visable Green banding problems on BENQ PROJECTOR
Discussion in 'Projectors, Screens & Video Processors' started by just wondering, Aug 7, 2005.
  1. just wondering
    just wondering
    Jul 25, 2005
    621
    Warwick
    +49
    Hi , i've just set up the benq 5120 my only source at the moment is a xbox via component output , the xbox is set to ntsc , when playing movies and games theres visable vertical green/dark banding on the screen , has anyone experinced this issue ? , the xbox is running at 480.
    Any help or advice would be welcomed.
    Paul.
  2. fallwood
    fallwood
    Sep 10, 2004
    864
    Leeds
    +6
    Like I said to you earlier its an xbox problem, some xboxes are known to show green banding over component, just posting it for the benefit of others.
  3. just wondering
    just wondering
    Jul 25, 2005
    621
    Warwick
    +49
    is there a way to force the xbox to output at 720 or 1080 ? or does the software/movie decide this ? i was going to hex edit my dvd playing software on the xbox to make it progressive....
    must say i'm not overally impressed by the 5120 benq , but i guess the real test will be the pc with higher res etc , i will plug the laptop in via the dvi cable and see what happens for regular windows....and maybe a game.
    wednesday/fridays sounds good.
    cheeeeers
  4. fallwood
    fallwood
    Sep 10, 2004
    864
    Leeds
    +6
    It should already be progressive if your running in ntsc mode, not played with the dvd software much but I think you can change res in the config options somewhere, is it the same evox dash that u put on mine with the same dvd software.
  5. just wondering
    just wondering
    Jul 25, 2005
    621
    Warwick
    +49
    yes its the same , i'm running the movies through the dvd region x , i've tried the media player , but i believe it won't let you play movies with menus.....
  6. just wondering
    just wondering
    Jul 25, 2005
    621
    Warwick
    +49
    Fallwood was indeeeeed correct , swapped over my xbox , now i have no green banding...i'm a much happier bunnie... :clap:
