virus stopping internet access
Discussion in 'Desktop & Laptop Computers Forum' started by realitybites, Feb 20, 2005.
  1. realitybites
    realitybites
    Jun 3, 2003
    613
    can anyone help. am currently using pda to go online as pc will not connect. double click on icon no go try explorer directly still no good. msn works ok and everyone else can connect wirelessly so connection is there.
  2. simon100
    simon100
    Nov 2, 2004
    319
    +11
    I take it you have tried to reboot the PC a couple of times.
    Also try going into explorer from within Windows explorer, as it might be that the icon link has broken rather than this being a virus.
    Have you run your virus checker and checked that the firewall is set to allow internet access?
    You could also reboot the router if it is a separate item as this sometimes freezes.
    Finally when you get on line download Firefox and use that, much less susceptable to problems than IE.
