Virus Problem, help!
Discussion in 'Desktop & Laptop Computers Forum' started by Greg Hook, Nov 14, 2004.
  1. Greg Hook
    Greg Hook
    Moderator & Reviewer
    Nov 25, 2001
    20,706
    In a secret location with Jennifer Lawrence
    +7,490
    I have the W32/Nachi-B virus on my PC.
    Fortunately Sophos has found it and tells me its denied access to it everytime my PC starts up, but I really want to delete it.
    Running the scan it tells me the virus is in the svchost.exe and do I want to delete it.
    Now checking over the net and other places, this seems to be a main windows file. Is it OK to delete?
    Greg
  2. rooney
    rooney
    Mar 7, 2004
    506
    midlands
    +33
  3. KraGorn
    KraGorn
    Aug 30, 2003
    4,740
    68
    Warrington
    +27
    No it is NOT safe simply to delete that file, SVCHOST.EXE is a general purpose utility used to run many of XP's background services .. it's name is a contraction of SerViCe HOST .. in fact you'd probably not be able to simply delete it due to it being in use, look at the Process list in Task Manager and you'll see several instances of it.
    From reading the link provided by rooney it seems that the virus isn't in that file .. again, since it's in use all the time a virus who have to work very hard to alter it .. so that's not the root of your problems.
    I'm surprised Sophos doesn't provide information on its' removal, have you checked their web site?
  4. KraGorn
    KraGorn
    Aug 30, 2003
    4,740
    68
    Warrington
    +27
    No it is NOT safe to delete that file, SVCHOST.EXE is a general purpose utility used to run many of XP's background services .. it's name is a contraction of SerViCe HOST .. in fact you'd probably not be able to simply delete it due to it being in use, look at the Process list in Task Manager and you'll see several instances of it.
    Have you any idea how you got it? It seems that it uses some long-patched exploits, were you not fully patched?
  5. Greg Hook
    Greg Hook
    Nov 25, 2001
    20,706
    +7,490
    Thanks for the replies.
    I have been to the Sophos website and it tells you to download a little program they have made. This scans your computer for the virus, if it finds it, it will prompt you if you want to delete the file. This was what I was referring to above.
    I have had it ages, probably got it the first time I connected to the net to download all the XP updates.
    I will try rooney's link and see what happens.
    Greg
  6. KraGorn
    KraGorn
    Aug 30, 2003
    4,740
    68
    Warrington
    +27
    Well, I guess they know what they're doing, I'd love to know how one can delete a file that's in use by currently active processes.
    Is this the page on Sophos you've seen? Have you run that utility they mention that tells you to delete SVCHOST.EXE?
  7. Greg Hook
    Greg Hook
    Nov 25, 2001
    20,706
    +7,490
    Yes, thats the one.
    I am sure they do know what they are doing, but still not confident about deleting an important file. Might have to email them and see what they say.
  8. KraGorn
    KraGorn
    Aug 30, 2003
    4,740
    68
    Warrington
    +27
    I think that's what I'd do if we got such a message here .. at work we use Sophos.
  9. Jayde
    Jayde
    try trend micro HOUSECALL free online AV
    I removed lots o worms with it..
    Same for spyware free online vers
  10. GagHalfrunt
    GagHalfrunt
    Sep 1, 2001
    522
    North Cotswolds
    +3
    I had to deal with a mass outbreak of this awhile ago.
    I've got a feeling that although it has the same name as SVCHOST is isn't in the same place so can be removed. But tbh it's just as easy to get the Fix from:
    Symantec removal tool
    And run it and let it do it's stuff. Welchia = Nachi btw.
  11. Greg Hook
    Greg Hook
    Nov 25, 2001
    20,706
    +7,490
    Thanks for the replies, I have let the sophos do its magic and it seems to be gone.
