Virtual PC 2007 - Terminal Service
Discussion in 'Computer Software & Operating Systems' started by the_grinder, Feb 9, 2009.
  1. the_grinder
    the_grinder
    Jan 6, 2009
    226
    Windsor
    +17
    Not sure if anyone can help me with my problem below?
    I've just installed Virtual PC 07 onto a networked PC.
    The host operating system is XP Pro and the PC is joined to our domain.
    The guest operating system is XP Pro and the virtual PC is also joined to our domain.
    From a completely different PC I can terminal onto the host machine without a problem.
    However, I'm trying to terminal directly onto the Virtual machine (using the IP address of the virtual machine) and it's failing to connect. [​IMG]
    The VM network settings are pointing directly at the host machine network adapter, not Shared networking.
    I've also checked Windows firewall (on both the host and the guest) to make sure that remote desktop is allowed through.
    I can also ping the vm without a problem.
    Any ideas? [​IMG]
  2. Uridium
    Uridium
    Jan 29, 2005
    14,434
    North West Leicestershire
    +1,855
    Have you enabled Remote desktop access on the XP virtual machine (it's disabled by default)?
  3. the_grinder
    the_grinder
    Jan 6, 2009
    226
    Windsor
    +17
    I believe I have started every service that I can think of (see attached screenshot)
    I've also made sure that remote desktop is in the exception list of both the host and guest Windows Firewalls.
  4. the_grinder
    the_grinder
    Jan 6, 2009
    226
    Windsor
    +17
    Now fixed!
    I hadn't even enabled remote desktop in the system properties!
    :oops:
  5. Uridium
    Uridium
    Jan 29, 2005
    14,434
    +1,855
    Yup that's the one i was reffering to. As it's enabled by dafualt in 2003 Server you'd be surprised how many people this catches out on an XP or Vista build ;)
  6. the_grinder
    the_grinder
    Jan 6, 2009
    226
    Windsor
    +17
    :D Thanks for your response!
