"Virtual" Dolby Pro Logic OR Flat Screen?
Discussion in 'General TV Discussions Forum' started by Major Dutch, Aug 27, 2003.
  1. Major Dutch
    Major Dutch
    Jul 28, 2003
    32
    11
    Hi all,
    Given my current budget and the fact I am buying a new house I would like your opinions on the following.
    I've been looking at 28" widescreen TVs and have noticed that I seem to be able to afford either a flat tube 28" with nicam sound, a standard tube 28" screen with nicam or a standard tube 28" with "Virtual" Dolby surround.
    My folks currently own a 28" widescreen with "Virtual" Dolby and I must say I'm not exactly blown away with it; it's pretty far from being surrounded by speakers TBH.
    So which of the options would you go for? I'm thinking 28" flat tube with standard nicam sound....
  2. GagHalfrunt
    GagHalfrunt
    Sep 1, 2001
    527
    North Cotswolds
    +3
    Yes, that's what I would go for.
    At least you can do something with the audio later on when you have more money. Virtual Surround and it's cronies sux imo.
    Ever since I have had an AV setup (which would sound 100x better than any TV would imo) my volume on my TV has been turned off.
  3. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    13,423
    Somewhere in South Yorkshire
    +5,823
    Personally, I'd never buy a TV on the strength of its audio features - they are NEVER going to be that good anyway. Audio on a TV should be seen as a pure convenience factor only. Buy on the strength of image quality. Audio is something that can (and should) be addressed separately, when funds allow.
  4. Greg Hook
    Greg Hook
    Moderator & Reviewer
    Nov 25, 2001
    22,740
    2
    In a secret location with Jennifer Lawrence
    +9,526
    I second that vote for the flat screen, nicam option
    Definitely what I would go for given your choices. As the others have said you can always upgrade the sound later to a full on system.
    Greg
  5. Major Dutch
    Major Dutch
    Jul 28, 2003
    32
    11
    Thanks for that chaps,
    Nigel made a good point about what a TV is really for, and that’s visuals, I can certainly add an audio system later on.
    So you've all tipped me over the precipice I was teetering on, Flatscreen it is :smashin:
