Virtual Dolby anyone?
Discussion in 'General TV Discussions Forum' started by atmoscinema, Sep 4, 2001.
  1. atmoscinema
    atmoscinema
    Aug 4, 2000
    2,122
    Leicester
    +51
    I've just ordered a Sony TV with Virtual Dolby,not for this feature though.I was just wondering whether anyone has tried Virtual Dolby and is it any good,as it is licenced by Dolby?
    Oh and how's it meant to work?
    [ 04-09-2001: Message edited by: Wayne Moule ]</p>
  2. torimusic
    torimusic
    I think it's a way of simulating surround sound without the rear speakers found in a conventional surround sound system. I'm not sure exactly how it works. It has something to do with sending the rear sound information to the left and right front speakers in a certain way that tricks your ears into thinking that there is sound coming from behind you. I just know that this is a cheap way of trying to create the surround sound experience. Ultimately you should have a proper 6 speaker setup with the appropriate surround processor/amp. You may be able to get more info from <a href="http://www.dolby.com" target="_blank">www.dolby.com</a>
  3. Stuart Wright
    Stuart Wright
    AVForums Founder Staff Member
    Jan 24, 2000
    14,773
    7
    2
    167
    Birmingham, UK
    +10,688
    JVC used to make a big deal about their virtual surround sound system in their tellys.<br />Ultimately it doesn't work as well as a real surround sound system, of course.<br />There might be some TV reviews on the HCC site worth looking at.
  4. AMc
    AMc
    Nov 20, 2000
    7,331
    Near Norwich
    +4,055
    I used to have a JVC TV with a Virtual Dolby Surround feature. As above supposed to give you surround effects without rear speakers, in actual fact just seperated the stereo a bit more (and ruined the soundstage). It was licenced by Dolby but I don't think that really makes it any better. My Samsung DVD has a virtual surround mode too that is basically the same thing - not recommended.
    AMc
