Virgin XL 20meg Broadband
Discussion in 'Virgin Media Broadband' started by hayesw60, Jan 19, 2008.
  1. hayesw60
    hayesw60
    Nov 16, 2007
    24
    3
    Liverpool
    Hello all
    Just got Virgin 20 meg broadband today, dont seem to get anywhere near that speed when I check my connection speed on speedtest.net does anybody else have this? the highest i have managed to get is 7meg
  2. limblee
    limblee
    Dec 21, 2006
    2,155
    67
    Ruislip
    +235
    What time did you test?
    I get around 4-10Mb between 7pm - 1am.
    +12Mb any other time.
  3. Blu4KHD
    Blu4KHD
    Dec 9, 2005
    2,491
    +427
  4. hayesw60
    hayesw60
    Nov 16, 2007
    24
    3
    Liverpool
    I upgraded this afternoon at aroud 2:30 so i have been testing since aroud 3 in the afternoon im currently not even getting 2meg at the moment, around 5 o clock i was getting 6meg
  5. hayesw60
    hayesw60
    Nov 16, 2007
    24
    3
    Liverpool
  6. mulauk
    mulauk
    Jan 18, 2008
    78
    i was only getting upto5mb on my 20mb line so i called up virgin after being shuffled around for over 45mins (costing over 15pounds in phone bills) they agreed to send an engineer out to test or replace box. When arrived he said i was getting the 20mb service but the samsung set top box(which was installed a year earlier when 10mb came out)couldnt handle the speeds. He couldnt authorize installing a cable modem, he had to get a managers permission, he took my mobile number said the manager would get in touch. Its no surprise to me that i havent had any phone call nothing. Same old crappy service when it was ntl.
  7. hayesw60
    hayesw60
    Nov 16, 2007
    24
    3
    Liverpool
    I have a motorola Surfboard SB5100 cable modem, this was provided when i got broadband first installed, has anyone had any issues with this?
  8. Rawlo
    Rawlo
    Mar 9, 2005
    96
    +8
    Best way to test your speed.
    In Google, search for "gamefiles". First link should take you to Blueyonder games. Start downloading a couple of the large demos. Add together the transfer rates of the downloads to get your speed. (You can cancel the downloads once you have worked out your speed.)
    I am on BB XL, have a Surfboard 4100 modem connected to a Linksys Wireless G router, and usually get download speeds of 1.5 MB/sec or greater.
  9. Azzin
    Azzin
    Nov 5, 2005
    23,836
    +3,072
    Try the Virgin Media Broadband forum, rather than the Cable TV forum that you've posted in. :smashin:
    http://www.avforums.com/forums/forumdisplay.php?f=322
  10. Fatal1ty
    Fatal1ty
    Jan 19, 2008
    259
    St. Helens WA9
    heres mine
    [​IMG]
  11. Kevin88582
    Kevin88582
    Ditch the wireless unless you have a wireless N router.
    Wireless will greatly slow down your connection.
    Look at my screen shots, one is when i connected wirelessly, and the other was with an ethernet cable.
    What a difference it makes, the ethernet cable is twice as fast and downloads four times as fast! (wireless downloads at ~ 500KB/s, whereas on cable i get ~2.1MB/s)
    Hence the reason virgin are reluctant to give out wireless routers on a 20Mbps connection.
  12. Naqv
    Naqv
    Oct 15, 2006
    3,627
    Birmingham
    +352
    I get (or used to until landlord decided to move to to M, but have told him to get XL again OR ELSE) full 20meg service, downloads were in the region of 2.4mb/s.
  13. samosa
    samosa
    Jan 14, 2009
    20
    mine runs at full 20.
  14. spikey1
    spikey1
    Jan 9, 2004
    459
    +18
    Well I'm on the 20 meg service and have been getting less than 1 meg for the last couple of weeks.
    Have tried 2 different laptops running XP and Vista and have hard wired direct to the modem. No difference really at all.
    Finally decided to call them tonight, first had the phone put down on me at 7.53 no doubt as the shift was about to end; then on redialing got the other call centre who told me there were problems in my area (there isn't the recorded message said it was an entirely diiferent part of Bristol) and that engineers were working on it and it should be fixed by tomorrow.
    When I asked if the engineers had been working on it for 2 weeks plus I didn't get a reply, nor did he understand there was more than one postcode and part of Bristol.
    I'll wait until tommorrow to prove a point but I think it's about time I look elsewhere. Problem is I'm pretty sure I'm along way from the exchange and ADSL speeds will be very limited.
  15. docster1234
    docster1234
    Jan 22, 2009
    11
    3
    I rarely get 20mb :(
  16. Damo
    Damo
    Dec 11, 2008
    61
    Got the XL package in October 08, and getting 19.6 download speed.
    Then again, the Fibre Optic box is just outside my garden wall, so only 3-4m of copper wire.
  17. tea_bag
    tea_bag
    Dec 4, 2007
    286
    28
    +76
    When I upgraded to 20meg some time ago, I was getting at most about 10meg fastest, phoned them up to say I wanted to drop down speed again because it was the same speed I was getting before - they said they will check it out and get back to me, 2 days later a new modem arrived in in the post and now am getting the full 20meg speed.:thumbsup:
  18. jameswtaylor
    jameswtaylor
    Mar 16, 2007
    77
    11
    +4
    So the big question... Is it worth the money because it doesn't sound like it?
    I currently have Sky broadband 2 meg and speed test says i'm getting 1.76!
    To upgrade or not ?
