Virgin WiFi - Connecting Two Hubs
Minchroadster
Hi all, new to the forum, so hoping you can help? Just moved into a new (large) house. I have a new Virgin super hub 2 into my living room but I also have another cable/ box on the wall, wired from the main outside box, into the study (other end of the house).
Can I connect another super hub to this second cable and use WiFi in the study. The current signal from the new super hub is VERY weak to the study - approx. 1/2 mbs.
Thoughts colleagues?
techquest
Is this a new service provided by Virgin as they now supply the so called Super Hub3 on new services?
Take a photo of the other box and post so we can see what it is you've got. Then we can provide a more definitive response.
Minchroadster
Hi, yes the new Virgin service is provided by their
Super Hub 3. Attached are some, poor pics, of the Virgin box and cable in the study. Having checked the Virgin box outside, I have appear to have an input (in) coaxial cable and two output cables? One to the new Virgin Super Hub 3 and one to the study which is currently connected to nothing. Could I fit another super-hub to this spare (?) lead and have wifi in the study? ?
techquest
You only have one service, one account and you can only connect one SHub3 as your main router. You could use a second SHub3 to serve as a hub by plugging a network cable between them, then turn dhcp off on the main SHub3.
This is what a normal setup would look like. The second box you have would be used to connect a Virgin TV Box.
Minchroadster
Thanks for this, most helpful - the diagram is perfect. Assume I need to login into the Virgin account to turn off the DHCP?
Mark
Similar threads
Podcast: New TVs, Samsung Q800T Soundbar review, IFA latest, Movie and AV News, B+W Brad Pitt
