Solved: V6 Box Upgrade - Self Install - Page 3 - Virgin Media CommunityI self installed last weekend - very easy to follow the clear instructions provided. Luckily I had a 5m ethernet cable which was needed as the 3m one provided wasn't long enough for where the two new boxes are sited.
We just did a self install of a free V6 to replace our old HD Box, but we couldn't order it online, because it was trying to tie us into a 12 month contract and increase the monthly cost, which the offer said wouldn't happen. The online order asks if the V6 is going to be in a different room to the Super Hub, but we weren't asked this over the phone, so were only sent a 3m Ethernet cable and a HDMI cable with the V6.
I decided to move the TiVo upstairs where the HD Box was and put the V6 in the living room, so just connected it to the Ethernet cable I was using with the TiVo.
I guess when you select the V6 is not in the same room as your Hub on the web order, that triggers the Powerline adapter being included. Would have useful to get another one.
The installer who told you that the ethernet cable supplied with self installs is only 1m in length was wrong. The cable is 3m in length.
