Virgin V+ and Sky HD sent to another room
Discussion in 'Cable TV & Virgin Media TV' started by worldmaster, Feb 2, 2009.
  1. worldmaster
    worldmaster
    Feb 1, 2009
    Having joined this forum yesterday I gained sufficient knowledge to unplug the HD cable from V+ and change the settings. I was then able to successfully link both my Virgin V+ box and Sky HD to another room :). I joined the Smart-Eye (for V+) and TV-Link (for Sky) in tandem, however, the sound on both is much reduced and the volume on the second tv has to be at maximum to be just acceptable :mad:.
    Also if the Smart-Blaster is not positioned very carefully it prohibits the remote control of Sky in the second room .
    Has anyone come across these problems :confused:?
