Virgin modem
Discussion in 'Networking & NAS' started by douglas, Mar 13, 2013.
  1. douglas
    douglas
    Aug 9, 2010
    5
    Pulled a V, super hub from a skip,bit scratched up no ssid or any markings on it. would it be usable ?
  2. limegreenzx
    limegreenzx
    Feb 9, 2006
    2,018
    +337
    The modem side is only of use on virginmedia network.
    Wifi performance is so poor I won't bother. It is disabled on my superhub, because it is so bad.
    It may be of some use as a 4 port switch as long as it is in a different subnet to your main router, otherwise you may get dhcp conflict or routes your data to a non connected modem. I think the default lan is 192.168.0.xx
