I've had the email from Virgin offering me this but I want to make sure it won't break my Sonos system before agreeing to it.
Do any of you have Sonos speakers and a Hub 5 ? Any issues?
YES!
Had the misfortune to set about my hub3 to hub5 'upgrade' today. I was nervous already reading this and many other forums. First off, it booted seemingly OK and then turned flashing green downloading an up to date firmware as expected. The leaflets with the unit said allow 30 minutes and 1 hr - why the difference? I did the ironing then took the dog out. 2hrs still flashing green! All through this I noticed my PC which is hard-wired via two gigabit switches would intermittently get a network connection and I could load pages albeit s-l-o-w-l-y. Wi-fi was similar. Not useable.
Called VM, immediately it recognised that I'd ordered the hub5 and offered me the 'do you want to activate it' option? Well there's nothing in the blurb about THAT being a needed step! I pressed for YES and got a text saying I was now activated but the problems remained.
Called again and got through to support very quickly for once - almost like they know?
Guy said lots of problems, it is just a trial you know (well the invite never said THAT!) advised a hard reset and he held on the line. It made no difference. I have an 8dB attenuator on my line and asked if I still needed that? He said try removing it! No difference. The app could see there were line issues. He raised a ticket and said they'd call in 4hrs...hopefully!
In the meantime I'm thinking what else can I do? In one of the booklets it does say don't site the hub5 within 1 metre of any other wireless device. In my service cupboard I also have my SONOS boost. Anyway, powered this off and lo and behold the internet sprung to life - ethernet and wifi flying! Powered it back up and it was dead again. Moved the boost to my office 25 feet away and it killed everything again.
It is almost like the Sonos mesh is messing with the hub5? Why it should mess the ethernet is mystifying? The Sonos is still running a mixture of hard wired and Sonos mesh. One thing might be I run an S1 system - do the old components only run 802.11 b/g/n and the boost runs ax as well and that is screwing it up? I'll monitor all this and report back. I have the option to switch the sonos to run off the wifi as well. Checked btw it is set up as ch 6. Not got as far as checking the hub5 setup. It has been exhausting. Still waiting for tech support.
