Hi please could someone explain this 930mbps wired limitation. I got a free upgrade from M600 to ,Gigabit via Volt but indeed only get 930 whereas I got 680 on M600
So there are two things, when Virgin supply a service the actual sync speed is often 10-12% faster than the advertised speed (but it’s the same for everyone at a given speed). When people then do Speedtest it gives a bit of headroom so that they should normally get the advertised speed and can’t complain against being missold.
It’s the same as when you buy a one litre bottle of coke for example they often will supply you 1.05 litres of coke because the filling machine is only accurate to 5% , so they guaranteed to not undo it which would be illegal in that case.
Then you have Gig One which is Virgin’s current top tier (till they launch 2.2Gbps) this you would expect to be 1,000Mbps but in reality it is 1,152 Mbps(from memory).
Gigabit Ethernet though is 1,000Mbps per port, however there are various overheads involved so the max throughput off measured will be in the order of 930-940Mbps.
If you use the gig one service with your own modem which a lot of people do then with a single connection you can only use 930 Mbps of the service.
That’s nearly a loss of 20% off the speed you are paying for.
The new super hub 5 has a 2.5Gb port so gets round this, or you do like me and others and buy even more equipment to get the full speed
