Virgin Media - Media Access Key
Discussion in 'Cable TV & Virgin Media TV' started by Glynn52, Mar 2, 2013.
  1. Glynn52
    Glynn52
    Mar 2, 2013
    2
    I've had Virgin tivo bos installed today and have downloaded the tv anywhere app to my i-phone but when i try and get the media access key in settings -system info - media access key, the boxes are empty (it's asking me for the key) How do I get the ket code?
    The app also asks me for the code. Seems like a catch22.
    Can anyone help please?
  2. limblee
    limblee
    Dec 21, 2006
    2,155
    67
    Ruislip
    +235
    Sounds to me as you'd type in any code you want.
  3. dante01
    dante01
    Mar 5, 2009
    45,832
    +10,948
    If you've not set a password on your TiVo then you should enter 1234 when asked for one. This is the TiVo default password. The 10 digit Media Access Key will be revealed to you after you enter the password. Take a note of it and use this key to allow devices to accessing it via TV Anywhere.
  4. Ernie_C
    Ernie_C
    Apr 2, 2006
    986
    46
    +111
    The MAK will not be there immediately as, I believe, your TiVo has to 'phone home' to authenticate. Try again in a few days and all should be OK.
  5. Glynn52
    Glynn52
    Mar 2, 2013
    2
    Thanks Ernie and Dante, that makes perfect sense and it all fits now so I'll give it a few days and try again
