Bepster00
Established Member
Today we have had Virgin Media 200mb broadband installed, replacing Sky 10mb non-fibre.
This was previously connected to Sky Q main box and 3 mini boxes used as access points.
Now I’ve moved from Sky can I still use the Sky Q Mesh?
I’ve also bought an ASUS AX5400 as I want to use NordVPN at a router level.
Currently I’ve connected the Super Hub 3 to the ASUS and turned off the WiFi on the Super Hub.
I haven’t put the Super Hub into Modem Mode as I want to use the Ethernet ports and I believe these are disabled in Modem Mode.
Do I need to do anything else with the Super Hub?
Should I turn off anything on the Sky Q boxes?
Is this the most efficient use of all of the components?
I’m showing 2 separate networks using my SSID name, not sure why this is.
Any help would be greatly appreciated.
