toffeejim2395
i have tried to connect a dm500 to a virgin internet hub and later a bt hub with an ethernet patch cable,both without any success.however when the same unit is connected to a standard talk talk wireless router ,also with an ethernet patch cable it works perfectly.any ideas why this is so?.are there any specific types of ethernet cables compatible with hubs,or are there any settings on the hubs that can be altered so the dm500 will work through the hub
