Vinyl to CD
Discussion in 'Hi-Fi Stereo Systems & Separates' started by Taz, Dec 6, 2003.
  1. Taz
    Taz
    A few questions so here go's....
    How easy is it to do vinyl to CD ?
    What is needed in the way of software ?
    I need just one vinyl album put on to CD can anyone help? (I own the LP so that makes it OK yeh?)
  2. overkill
    overkill
    Nov 6, 2003
    11,778
    Murkeyside
    +1,194
    If you have Neros "wave editor" it should be no prob. Any other software requires payment for more than one copy so they ain't much use if you only want to do 1 CD!!! Its fairly straight forward as you create one file for each track, then just let nero burn it to CD. RipVinyl is even easier. Just download it and go!!!
  3. Taz
    Taz
    Thanks, Is it just a case of connecting my deck to my soundcard then?
  4. overkill
    overkill
    Nov 6, 2003
    11,778
    Murkeyside
    +1,194
    Eek no!! Turntables need RIAA equalisation and that means running thru their phono stage. Connect your Line out (tape out) from the amp to your sound card.
  5. Taz
    Taz
    :eek: OK thanks for that advice.
    Looks like its going to be a bit of a pain for me then running cables and the like :(
    Can anyone help me out with this please?
    I'll pay for your time ;)
  6. fatbaldbloke
    fatbaldbloke
    Dec 3, 2003
    19
    3
    Whats the Album?
  7. MarkE19
    MarkE19
    Aug 10, 2002
    17,132
    Rainham Essex
    +2,393
    Taz,
    I've got a turntable (not great quality) and a CD recorder on my HiFi. If I've got the album or you can get it to me I will put it onto CD for you.
    I'm about 6 miles inside the M25 by the Dartford tunnel on the Essex side if you are coming close to me as I would not like to post vinyl.
    LMK
    Mark.
  8. overkill
    overkill
    Nov 6, 2003
    11,778
    Murkeyside
    +1,194
    To be honest Taz for one album its not worth the effort. If one of the guys can do a c*py then that's got to be easier!!!
  9. Taz
    Taz
    Thanks for all the replies everyone..
    Im waiting on the album to be delivered then it looks like im off to Essex to pay MarkE19 a visit :D
    Thanks again
  10. MarkE19
    MarkE19
    Aug 10, 2002
    17,132
    Rainham Essex
    +2,393
    No problem Taz, I look forward to your visit.
    I'll send you a PM with my phone number to make life a little easier.
    Mark.
  11. Taz
    Taz
    Thanks Mark :smashin:
    Hope to see you soon. :)
