Vinyl Floor Adhesive
Discussion in 'General Chat' started by nheather, Sep 23, 2017.
Tags:
  1. nheather
    nheather
    Oct 6, 2004
    19,918
    167
    Horsham, West Sussex
    +10,220
    Redecorating a small bathroom. When the vinyl was original installed it was left floating rather than being glued down. This would be fine if it were a perfect fit, but there are 1-2mm gaps all round so over time the vinyl will move slightly causing it to bunch up on one edge and create a bigger gap on the other edge.
    I want to position it properly and glue it down but just at the edges.
    Do I need to use proper vinyl adhesive or would a bead of silicone sealant do the job well enough. Once it is down I'm going to run a silicone bead around the vinyl<>skirting edge to hid the poor fit.
    Cheers,
    Nigel
  2. Roohster
    Roohster
    Jul 1, 2004
    4,649
    7
    Derbyshire
    +5,650
    Silicone sealant isn't strong enough, get some proper adhesive or use double sided tape.
    It'd be better still ( though obviously harder to remove) if you glued the whole area.
  3. True Romance
    True Romance
    Feb 7, 2005
    6,973
    Wolverhampton
    +3,032
    adhesive spray
  4. baker
    baker
    Aug 20, 2006
    1,508
    116
    Woodbridge
    +710
    On a similar topic,
    I'm looking to put down a vinyl floor too in my bathroom just to freshen it up in preparation for possibly putting the house on the market. Currently the new build developer fitted carpet, so underneath is a mdf/chipboard floor boards.
    Do I need to lay a thin 5mm ply over the top?
  5. McVicar
    McVicar
    Mar 31, 2015
    5,874
    163
    It's funny you should ask that...
    +8,259
    Why?
  6. baker
    baker
    Aug 20, 2006
    1,508
    116
    Woodbridge
    +710
    God knows, but it's been on my list of things to replace for years!
  7. McVicar
    McVicar
    Mar 31, 2015
    5,874
    163
    +8,259
    But you said new build developer which made me think this is a new build. When was the house built?
  8. baker
    baker
    Aug 20, 2006
    1,508
    116
    Woodbridge
    +710
    2006, I was just implying that it was the developer who fitted the carpet rather than myself... as I don't get why anyone would want to put Carpet in the bathroom.
  9. Bl4ckGryph0n
    Bl4ckGryph0n
    Sep 11, 2003
    43,348
    11
    13
    167
    ::1/128
    +16,686
    Agreed, never seen it anywhere in the world until I moved to the U.K. I really don’t get why anyone knowingly would do that.
