Quantcast
Viewsonic Viewpad 10e
lafemme
I bought a Viewsonic Viewpad 10e yesterday and it has the option of two types of home screen, one looking like standard android and the other the viewscene 3d mode - somehow I have 'lost' the viewscene 3d mode and cannot locate it. Its not an application so its not as if there is something I can click on.
Does anyone know how I go about getting this back as I want to start customising the pages!?
maf1970
Settings >Applications > Manage application > ViewScene 3D > Clear defaults.
lafemme
Hi, this is what it says to do on Viewsonic's page but there are no defaults to clear, so I was not able to do this.
maf1970
Viewscene 3d is launched by the home button only.
Then press Home key to view the launcher selecting menu. In the launcher selecting menu, check the "use
by default for this action" check box and select ViewScene 3D.
lafemme
I am going to do a factory restore (only got it yesterday) because home button is not doing anything and if I hold it down I get "recent applications" no option at all for 3D mode.
Similar threads
