Viewsonic N3200W
D
DazzaL
Was thinking of getting one of those, as it seems its got good connectivity like DVI(HDCP)/component etc. Does anyone have any opinions on this?
looking for a 32" screen with DVI-HDCP (futureproofing?), headphones, component inputs, PaP
thanks.
Daz.
peahead
me to would like a opinion on this tv i now the viewsonic n3000w got good reviews but does anyone have this tv.
jimsan
Established Member
I don't think many will have this one yet. Certainly the N3000W was well recieved...
Jimmy
D
djsat2
I have a N3000W and while ive never had an LCD before this is a great set. Ive had it since Nov and no dead pixcels as of yet and I havent had any problems with the TV. It caters for my HTPC (DVI), NTL box (SCART) and Xbox with Hi-def (Component) easily and still has plenty of plugs to spare. The remote is a bit of a monster but i very rarely use it. There are no fans etc so the unit is very quite and the picture quality seems excellent. As this is my first big LCD iporbably dont scrutinise as much as other users might but from my perspective this is a great screen and I cant' find much wrong with it.
Nicky
Established Member
I ordered a N3200W and it went straight back. It had terrible fogging from the backlights in each corner of the screen. Someone else commented on this briefly a few weeks back so it's possible this is a general problem. That said it was so bad I find it hard to believe they would expect to sell any if they were all as bad as mine. It also seem pretty poor at black detail, but bright pictures did look great.
It was a shame, as design wise it looked fantastic. The speakers detach which they don't mention in the spec which is handy.
If you do go for it I'd find it somewhere you can return it easily.
I've seen a N3000w on demo and that looked fine. This was my basis for buying the N3200w. Any problem seems specific to 3200.
Nick
Rocky 4K, Creed 3 and boxing movies, Shazam 2, 65 trumping Jurassic World Dominion, + Picard & Mando
