Viewsonic N3000W LCD TV - 30" HD Ready - £669
Discussion in 'LCD & LED LCD TVs' started by mooseepoo, Jul 22, 2005.
  1. mooseepoo
    mooseepoo
    May 11, 2005
    182
    Click Me!
    Not bad for a shade under £700
    Features
    • Experience wide-screen HDTV ready
    Enjoy wide-screen and high-definition TV with true 1280x768 resolution and XtremeView® angles for a higher quality image at virtually any angle.
    • Stunning TV, vivid graphics, sharp text
    Ultra-high brightness of 450 nits (typ) and a high contrast ratio of 500:1 (typ) bring you rich, saturated color images and crisp text.
    • Advanced image processing
    Integrated motion adaptive progressive scan, 3-D comb filter and 3:2 pull down give you a larger, clearer picture with fewer artifacts. Low level contrast enhancement brings clarity to darker images.
    • Connections for all your multimedia components
    Multiple inputs provide easy connection of video accessories. The integrated DVI-HDCP input gives you the best HDTV images regardless of your signal source and dual TV tuners give you full picture-in-picture (PIP) capability.
    • High-quality stereo audio built-in
    Four built-in stereo speakers deliver 20 watts of stereo sound to your multimedia presentations. Stereo connections also allow you to enjoy stereo audio through an external sound system.
    • Clear, fast paced presentations
    The super-fast 16ms video response time keeps your presentations and video crisp and clear.
    Additional Specifications
    • Input 1 1xSVHS, 1xCVBS, 1xR/L audio
    • Input 2 1xSVHS, 1xCVBS, 1xR/L audio
    • Input 3 1x RCA component (YPbPr), 1xR/L
    • Input 4 1x RCA component (YCbCr), 1xR/L
    • Input 5 RGB D-sub 15pin, 1/8" stereo mini jack
    • Input 6 DVI-D (HDCP) (audio shared with input 5)
    • Input 7 1xCVBS, 1xR/L audio
    • RS232 Firmware upgrade/service port - no user function
    • Tuner 2x
    • PC compatible from VGA up to 1280x1024 non-interlaced, 1280x768 preferred with 3.5mm mini-stero audio
    • Mac® Power Mac™ up to 1280x1024,1280x768 (preferred) Adapter may be required. Analog adapter available from ViewSonic.
    • Speakers 2x10-watt
    • Output 1 Audio output, 1xR/L (line level/variable)
    • Output 2 1xsubwoofer output
    • Output 1 1xRGB D-sub 15-pin
  2. zag2me
    zag2me
    Nov 24, 2004
    228
    +17
  3. mooseepoo
    mooseepoo
    May 11, 2005
    182
    Click on the Link at the top of my 1st post!
  4. Iggy21UK
    Iggy21UK
    Jul 3, 2005
    35
  5. DaveP
    DaveP
    It ticks all the right boxes apart from the fact it's yet another 15:9 screen.
    This may or may not be an issue with you. I like the extra lines when using as a PC monitor but it's an irritation when watching movies or other 16:9 material.
    Dave
