viewsonic 30" ??? any good?
Discussion in 'LCD & LED LCD TVs' started by RockStar, Apr 21, 2005.
  1. RockStar
    RockStar
  2. leeboy22001
    leeboy22001
    Apr 18, 2005
    1,021
    48
    +43
    Hi, sounds like you need to stay well clear of this one.... just looked up the product on viewsonic website and yes it has 2 x NTSC Tuners! it is designed only for the American market! big no no
  3. leeboy22001
    leeboy22001
    Apr 18, 2005
    1,021
    48
    +43
    Have sent saverstore customer services an email stating this TV is designed for the American market because it has 2 x NTSC tuners! wouldn't want there customers returning the TV because they can't receive terrestrial TV! :eek:
  4. leeboy22001
    leeboy22001
    Apr 18, 2005
    1,021
    48
    +43
    Full spec:-
    * Panel Type 30" (29.53" viewable diagonal area), TFT (Thin Film Transistor),
    Active Matrix WXGA LCD, 1280*768 vertical stripe
    *Color Anti-reflective coating + Anti-glare coating
    *Viewing angles 170° (H) / 170° (V)
    *Input signal Video/Audio RGB Analog * 1 (75 ohms, 0.7 Vp-p)/Mini-Stereo *1
    *H/V separated (TTL) for PC
    *DVI-D * 1 (HDCP support)
    fh:30-80 kHz, fv:50-75 Hz
    *TV system antenna / NSTC in US and TW * 2
    *Composite Video * 2 / RCA (L/R) Stereo * 2
    *S–Video * 2
    *Component Video * 2 (YCbCr / YPbPr) / RCA (L/R) Stereo * 2
    *Composite * 1 / RCA (L/R) Stereo * 1, Headphone Mini-Stereo *1
    *RS232
    *Output signal Video RGB Analog * 1 (75 ohms, 0.7 Vp-p)
    *RCA (L/R) Stereo * 1
    *Subwoofer RCA * 1
    *Compatibility PC Up to 1280 x 1024 Non-interlaced
    *Macintosh1 Up to 1280 x 1024
    *Resolution Supported 1280 x 1024 @ 60, 75 Hz
    1280 x 768 @ 60, 75 Hz
    1024 x 768 @ 60, 75, 85 Hz
    800 x 600 @ 60, 75, 85 Hz
    640 x 480 @ 60, 75, 85 Hz
    720 x 400 @ 70 Hz
    Recommended 1280 x 768 @ 60Hz
    *Speaker Output 10W (x2 Channels)
    *Power Voltage 100-240 VAC, 50/60 Hz (auto switch), 0.8A/1.8A
    *Operating conditions Temperature 32° F to + 95° F (0° C to + 35° C)
    *Humidity 20% to 90% (no condensation)
    *Altitude To 10,000
    *Storage conditions Temperature -4° F to + 140° F (-20° C to + 60° C)
    *Humidity 5% to 90% (no condensation)
    *Altitude To 36,000
    *Dimensions Physical 860 mm (W) x 524 mm (H) x 203 mm (D)
    *Weight Net / Gross 37.5 lb (17.0kgs) / 48.5 lb (22.0kgs)
    *Regulations FCC-B, UL / c-UL, DOC-B, NOM, CE, MPRII, CCC, BSMI,C-Tick
    *Power saving On 185W (Blue LED)-
    *modes Active Off <3W (Orange LED)-
    *Preset Timing Mode (Pre-adjusted to GTF 1280x768 at 60Hz)-
    *Warning: Do not set the graphics card in your computer to exceed these refresh rates; doing so may result in
    permanent damage to the LCDTV Display.
    Note: Product Specifications are subject to change without notice.
  5. leeboy22001
    leeboy22001
    Apr 18, 2005
    1,021
    48
    +43
    Appologies for going on :rolleyes: admittedly this would be fine as a PC monitor, but for your money there are cheaper 32inch LCD to do this, dabs do one for £799, and has a PAL tuner too :D also the viewsonic does not have any scart inputs, and its only RGB input is via PC D-SUB.
  6. GrahamC
    GrahamC
    Jul 22, 2001
    2,258
    Morecambe, U.K.
    +67
  7. leeboy22001
    leeboy22001
    Apr 18, 2005
    1,021
    48
    +43
    nice TV :) just had another look at viewsonic TV since i've been told by savastore that my email has been passed onto the right department, and guess what the cheeky gits have modified the spec by removing the NTSC tuners to fool customers! :eek:
  8. leeboy22001
    leeboy22001
    Apr 18, 2005
    1,021
    48
    +43
    Maybe they screwed up the spec as there is a european model European N3000W :confused:
  9. mike7
    mike7
    Jan 3, 2005
    4,596
    Norwich
    +503
    No mention in the European Spec as to what tuner/s it has on board....strange this should be left out. Another 15:9 panel I'm afraid.
  10. jimsan
    jimsan
    Oct 8, 2004
    1,610
    41
    Dumfries, SW Scotland.
    +9
    You guys are all reading the specifications for the US model only! Get a grip! The Euro one has the right tuners and has scarts.
    http://www.homecinemachoice.com/cgi-bin/displayreviews.php
    As you can see it is fairly highly regarded, but that was a few months ago, and there are other sets around now with similar abilities and full 16:9 aspect ratios.
    Probably best avoided then, even at £1000, but not because of its connectivity which is excellent!
    Jimmy
  11. leeboy22001
    leeboy22001
    Apr 18, 2005
    1,021
    48
    +43
    Hi Jimmy, i do understand that there is a european model (as i mentioned earlier) but the saverstore website link if you go to product specification you'd see they spec the US model!?? :confused:
  12. jimsan
    jimsan
    Oct 8, 2004
    1,610
    41
    +9
    Huge apologies!
    Dis you have a look at the 32" version? Couple of hundred pounds dearer but OK. 15:9 again though.......no good really.
    Jimmy
  13. leeboy22001
    leeboy22001
    Apr 18, 2005
    1,021
    48
    +43
    Apology accepted :D 32in looks nice :cool: but expensive
  14. djsat2
    djsat2
    I have this unit and while ive never used the built in tuners im pretty sure the manual says PAL, i bought mine from savastore.
    Its a great screena and while this is my first large LCD screen im very happy with it and its performance. I dont have any dead pixels and have never had any evidence of blurring or slow response times.
    I have a xbox hooked up (hidef, halo 2 looks good), NTL digital, a PC (via DVI, got the right res and playing hi-def clips looks good) and a gamecube. The only draw back i found were that for me the speakers were inadequite and are not removable so while i have my own sound setup the TV speakers are redundant.
    Im veyr pleased with this unit and would reccomend it, just p!ssed that the price on it has come down so much since i bought it last nov.!!
  15. RockStar
    RockStar
    can you guide me in the right direction?
    I'm thinking of building a home media centre with Xp MCE...
    anyone got any experince?
    my main question is can a MCE box be domained and join a LAN ???
    ta
    R
