Viewing Webpage Help
Dazo
Changed over from Be to O2 today and although there should be no change am having trouble viewing many websites. This one still works however many of my favorites and pages like Google sometimes won't load. Is this to do with O2 or coincidence ?
Anyone got any tips ?
EndlessWaves
Without knowing what trouble you're having viewing them it's going to be difficult for anyone to say.
Did the change over from O2 to Be involve changing any equipment?
Dazo
No change of equipment i use my own netgear router. Should have said the trouble i am having is i get Webpage not found errors.
SeanT
More like SNR issue imho. Check your signal to noise ratio on your new connection.
Dazo
ADSL Link
Downstream Upstream
Connection Speed 16419 kbps
Line Attenuation 24.5 db
Noise Margin 7.4 db
Upstream
Connection Speed1300 kbps
Line Attenuation 10.7 db
Noise Margin 6.9 db
It seems my downstream SNR has raised from around 6-6.2 to 7.4 since the change over from Be to O2. Anyone idea why this would happen as i assume the SNR was to do with the line and not the ISP ? :confused:
SeanT
Have you tried flashing your netgear router with the latest firmware?
Dazo
Already on the latest firmware i am beginning to to suspect this may be the problem. Only updated it a few days ago but i don't think the router has been right sense. Changing from Be to O2 should have made no difference other than in name as they are the same provider.
Tonight i have used DMT tool to lower the SNR to 6.2 and that made a difference for a while. Then had a few problems again so i used Opendns servers and so far it seems to have help. Time will tell but i fear the firmware upgrade may disagree with my setup.
SeanT
Is it a DG834GT using 1.02.14? Mine was a bit squiffy for a while on this firmware but then seemed to sort itself out. Try 1.02.13 if it carries on (assuming it's a GT)
Dazo
It is the DG834N mate and so far it seems to have sorted itself out.
Similar threads
Podcast: Panasonic HX800 TV + Sony HT-G700 Soundbar reviews, movie and TV show news and reviews
