Viewing NTL via Windows Media Centre PC
Discussion in 'Cable TV & Virgin Media TV' started by jrd31, Aug 25, 2005.
  1. jrd31
    jrd31
    Dec 23, 2004
    59
    Hi my friend has built a pc with windows media centre on it, he has used a leadtek PVR2000 video card. He has connected a cable from the NTL stb box to run from the rf socket on it to the video card. Unfortunetly windows media centre cannot detect an aerial signal when trying to set up wmc, when scanning for channels on the video card directly he still cannot get a signal.
    The cable works as we connected that from the rf socket on the stb direct to the tv.
    Can anyone help with some advice on how to get the ntl feed from the stb box to the windows media centre pc?
    Thanks in advance.
    jase
  2. Spacecat
    Spacecat
    Apr 1, 2001
    3,349
    London
    +984
    if it takes a svideo signal try that instead or composite
  3. jrd31
    jrd31
    Dec 23, 2004
    59
    Ok i'll give that a go, if anyone else has any suggestions then please feel free to shout!
    cheers
  4. jrd31
    jrd31
    Dec 23, 2004
    59
    ok just looked at the pvr 2000 card. If i connect a scart from the ntl stb and then use an adaptor to plug into the svideo in /composite connection to the card will it pick up the feed and then will windows media centre pick up the ntl signal for it to work?
  5. jrd31
    jrd31
    Dec 23, 2004
    59
    OK
    i've bought a scart cable with an s/v connector and plugged it into the back of the pvr card but still i get no signal.
    Can anyone else help?
  6. meansizzler
    meansizzler
    May 11, 2005
    7,892
    104
    London
    +343
    The box does not output svideo, use composite, also you need the media center remote and recieverv as you have to hook up the IR blaster cables up to the set top box so media center can change channels..
  7. AV Junky
    AV Junky
    Oct 30, 2002
    1,214
    Staffordshire, UK
    +69
    I've participated in another thread on this very same subject very recently. Have a look, as your situation is the same.
