Viewing Hours On A Panasonic 5 series
D
dfh28
Does anyone know how to get the screen to provide information on how many hours it has been on in its life.
I know how to get into the menu that lets you put wobble on etc but is there another menu with this type of information.
Many Thanks
Derek Hughes
toonarmy
This works on the Panny 4 series
Press and hold the volume - button on the front panel and then press the recall button (this is the button directly underneath the red on off button on the remote) 3 times quickly (within 1 second).
You should get a screen showing 4 modes select SD mode and press action on the remote.
The number beside the PT is the of usage in hours.
To exit press them R button highlight ID mode and turn off the power switch on the front panel.
Careful what you are doing as you could void your warranty if you enter any of the other modes and change any of the settings
Toonarmy
D
dfh28
Got into that menu and found what i was looking for
Many Thanx
Derek Hughes
