viewing distance
Discussion in 'LCD & LED LCD TVs' started by theo, Mar 30, 2005.
  1. theo
    theo
    can you help me please buy the correct size lcd.
    distance from screen will be 2 meters,shall i go for a 26" or 32".
    also it will be connected to an iscan hd+ and i am thinking of xelos a series.
    thanks for your help in advance.
  2. jimsan
    jimsan
    Oct 8, 2004
    1,610
    41
    Dumfries, SW Scotland.
    +9
    At 2 metres the 32" should be OK....just!
    Jimmy
  3. richjthorpe
    richjthorpe
    Aug 2, 2004
    2,026
    41
    dat london
    +13
    Our viewing distance is 2.8m with our 32" LCD. Personally 2m is pushing it but should be ok. Also think of the future, will you put this tv in another room if/when you move ? You don't want to be buying another LCD in about 2 years because the first one isn't big enough.
    Richie.
