Viewing BBC1 on sky ... aspect ratio
Discussion in 'Sky Digital TV Forum' started by markbigears, Dec 16, 2004.
  1. markbigears
    markbigears
    Dec 30, 2003
    516
    chalk, Kent
    +18
    Whats up with BBC? is it always like this? while watching in 16:9 all the heads are streatched in the vertical. BBC2 is fine..... can some one help, hate switching the sky to 4:3 to view every time.
  2. Starburst
    Starburst
    Jul 13, 2000
    17,838
    Ilkeston
    +979
    Sounds to me you are taking the anamorphic 16:9 output of the digibox and viewing it as a 4:3 picture. You should check the plasmas settings, it may have been looking for a switching signal to reset the ratio and it never got it or maybe you have manually set the ratio incorrectly.
    Since you say that BBC2 is fine that it points more to the BBC1 ratio switching being the main issue.
    Have you tried any of the other BBC1 regions to see if it makes a difference?
  3. markbigears
    markbigears
    Dec 30, 2003
    516
    chalk, Kent
    +18
    cheers starburst, Plasma is set to 16:9.... very strange....am viewing london region, will have a look at another region, thanks for the info. Mark
  4. GalacticaActual
    GalacticaActual
    Jun 1, 2004
    5,710
    Galactica C.I.C.
    +223
    If you are watching using a sky digi box, make sure that the picture settings are correctly set up. IE, RGB and 16:9 wide :)
