viewing avi video via laptop to plasma...
Discussion in 'Desktop & Laptop Computers Forum' started by stolt, Oct 5, 2004.
  1. stolt
    stolt
    Oct 19, 2003
    328
    rayleigh, essex
    Hi ive got my laptop connected up to my plasma via the sony strb 940 amp the picture displays fine quality wise and with the sound. I just cannot get the video to fill the screen, is this possible I'm using the divx player and messed around with the video display settings but whatever I do I just cant get it o fill the screen, I understand its wide screen so i'll get bars on the top and bottom but these are bars on the side of the screen aswell... any help should I be using another player maybe that will give me the true width of the plasma.
    I cant figure out the aspect of my plasma maybe I can change that in the divx settings to get the picture.
    thanks for taking the time to read, hopefully this is in the correct forum.
  2. KraGorn
    KraGorn
    Aug 30, 2003
    4,740
    68
    Warrington
    +27
    Not sure, I don't use that player, but a quick poke around the menus doesn't show it has the ability to re-size the image to fill the screen.
    Try something like ZoomPlayer, I think that can do so.
  3. stolt
    stolt
    Oct 19, 2003
    328
    rayleigh, essex
    thanks I'll google that.... on the laptop it goes straight to the end of the screen its just when it is transferred to the plasma....
  4. KraGorn
    KraGorn
    Aug 30, 2003
    4,740
    68
    Warrington
    +27
    Hmm, that could easily be the laptop panel itself scaling I guess, really not sure though.
  5. stolt
    stolt
    Oct 19, 2003
    328
    rayleigh, essex
    thanks for the suggestions kragorn... Ive downloaded the doomplayer (havent had a chance this monring co I had to go to work) but I'll see if that can do really frustrating because its a picture in a picture if you no what i mean with banding around all the sides and no matter what I do I cant get it to the edge of the screen of the plasma, tried real player, windows media playuer 10 and divx player none of them can do it....
    Am I right thinking that Ive downloaded a film that cant be made any wider?
  6. gchuva
    gchuva
    Sep 26, 2008
    When I watch an avi video on my 50" plasma, the picture quality is very poor. Is there a way to improve this in terms of the player or the files that I download?
