Viewing angle - under 18 inch LCD
Discussion in 'LCD & LED LCD TVs Forum' started by phancey, Aug 23, 2005.
Tags:
  1. phancey
    phancey
    Dec 13, 2004
    22
    I recently bought a Philips 15PF7846 from Richer Sounds for £250 - I know this model has been superceded but it seemed like a reasonable deal.
    Having said that, I'm wondering whether I could have done better for the money - what do you think?
    Specifically I am using it in the bedroom, viewing from about 8ft away and about 2 or 3 feet below the TV level. Consequently it seems quite dark (kneeling on the bed shows that the picture is considerably brighter when viewed on the level). I can't angle the screen down. Would there be a better set (I still have 10 days approval period)?
    thanks
    Phil
  2. b1g1an
    b1g1an
    Aug 15, 2005
    385
    28
    +90
    Take it off the stand and use a bracket then you can angle it as much as you like !
  3. phancey
    phancey
    Dec 13, 2004
    22
    could do though it means further expense and my bedroom isn't ideally set up for wall mounting.
    Any other ideas?
