viewing a 3d tv direct
eddgreen25
im shortly getting a 3d tv
it would be wall mounted
i read that a 3d you need to view it directly
my set up i would be looking up to the tv above eye level
is this ok to view the 3d
mjcairney
If I were you, I would think twice about mounting any TV, be it 2D or 3D, above eye level, as I could well imagine ending up with a sore neck after watching it for a while.
Otherwise, if this doesn't concern you, I'm not sure whether you would need to view it directly or not.
Cheers,
Martin.
Kalos Geros
Aside from neck strain, vertical viewing angles on LCD and/or LED TV are even worse than horizontal...not a good idea, and could impact picture quality (color, black levels), and probably 3D experience would take a slight hit consequently...
plasmas are different, you can only suffer from a painful neck...
Sunshinewelly
I have new samsung plasma 3d TV which is mounted above my fireplace - my eye level is at the bottom of the screen.
I have not noticed any difference in picture quality and had no problems with a sore neck etc.
i wouldnt worry about it.
LCD TVs though do benefit from being watched straight on
tazza
The optimum height for a wall mounted TV is 600mm from the floor.
