Vieras: European Vs UK
Discussion in 'Plasma TVs' started by miket, Jan 11, 2005.
  1. miket
    miket
    what are the principle differences apart from price between the UK Vieras and the European Vieras? I'm wondering because if I buy a 42 inch Viera here I spend 2,600 Euros (1,800 Sterling) which is lower than the price for the UK model. I know that the UK model includes a digital tuner, is there anything else? I suppose that for picture quality etc on analog stations / DVD etc there are no differences?
    thanks in advance if anyone has some info.
    Mike
    (Italy)
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,299
    +1,215
    UK warranty may be different as well (not necassarily better)
  3. grande_assiette
    grande_assiette
    Hi Mike,
    Can you please tell me WHERE you can get the spec shown at this price.. I'm in Cyprus and the UK spec isn't any good to me..
    GA
  4. SKA.face
    SKA.face
  5. grande_assiette
    grande_assiette
    Vielen Dank :clap:
    wow, and it is a multi std tv in this spec.. Built in UK DVB Freeview receivers aren't much good in Cyprus !!!
    GA
