Viera wall mount from AV sales.
Discussion in 'Home Cinema Buying & Building' started by Starky, Sep 2, 2004.
  1. Starky
    Starky
    Aug 31, 2004
    46
    I was looking at this and it seems pretty good, has any Viera owner got this and are they quite easy to fit?, cheers in advance for any help.
  2. Si133
    Si133
    Hi Starky,
    I can't speak for that particular bracket (I bought a viera bracket on ebay) but they are all fairly similar in the style in which you put them up.
    I was scared of getting it wrong, but it really was easy. I was putting it up on a breeze block wall, with 4 heavy duty screws and it took half an hour. The key is a good drill bit.
  3. Starky
    Starky
    Aug 31, 2004
    46
    Si, was yours the 37 or 42 inch model, I believe the 42 inch weighs in at 41kg, which is a helluva load. I don't get it till next friday but I've bolted some wood panels onto breeze blocks using rawl bolts and run some cables in then replaced the plaster board, like yourself I'll probably use some heavy duty screws to fit the bracket (maybe use more than four though :p , lol)
    Regards.
  4. Si133
    Si133
    Mine is the 42. I used the heavy duty Focus screws that utilise a metal push out raw plug (they came in one pack). They go 11cms into the breeze block. tighten with a ratchet, not a spanner. I can hang on my bracket and it won't budget an micrometre.
  5. Starky
    Starky
    Aug 31, 2004
    46
    Cheers Si, sounds like a good solid mount.
  6. Starky
    Starky
    Aug 31, 2004
    46
    Just ordered one anyway, surely somebody must have one of these, come on peeps.
  7. Punjabmax
    Punjabmax
    Just got my plasma screen last weekend, is a faantastic screen but the universal wall mount i got was a bit tricky to fit on, as for some reason it didnt avoid the bottom panel that comes in. However i solved this by using it a different way than shown in instructions. Its now been on the wall for 2 days and 3 hours.. :confused:
  8. Starky
    Starky
    Aug 31, 2004
    46
    Hi Punjabmax, is yours the tilting bracket from AV sales?, I got mine in this morning, jeez....it's heavy duty quality :) , I'm a little worried about the fixings, still i've all weekend to hook it up, Viera comes friday :clap:
  9. Starky
    Starky
    Aug 31, 2004
    46
    Got it all hooked up now, superb, was a little disappointed at how far out from the wall it sits (almost 7'') however I can live with that.
