Viera Wall Mount Bracket
Discussion in 'Home Cinema Buying & Building' started by cwoj, Nov 12, 2004.
  1. cwoj
    cwoj
    II have just bought a spanking 42" Viera with Floor Stand, but to be honest i wall to and will wall mount it. :thumbsup: :thumbsup:
    Can anyone recommend a good bracket for it? I'd like something with a tilt, but not that important!!
  2. cwoj
    cwoj
    anyone? :(
  3. Leigh_1973
    Leigh_1973
    Jan 28, 2004
    721
    UK
    +16
    theres a few knocking around if you check out the forum sponsors! :)
  4. Starky
    Starky
    Aug 31, 2004
    46
    I can recommend the one from av sales, quality solid bracket with the tilt facility, however, because of the viera's design you have to buy the extension kit too, still a great price with the power buy, hope this helps, regards. :thumbsup:
