Viera wall bracket advice.
Discussion in 'Home Cinema Buying & Building' started by Jazz Monkey Jr, Jun 8, 2005.
  1. Jazz Monkey Jr
    Jazz Monkey Jr
    Jan 10, 2005
    14,242
    2
    4
    137
    Garstang, Lancs
    +1,625
    I have ordered a PV500 from RGB direct with the wall mount. I assumed the wall mount was a panasonic one, but when I looked on their website it says universal bracket:
    http://www.rgbdirect.co.uk/referrer.asp?SKUNumber=103469&ReferrerCode=4
    The bracket is:
    http://www.rgbdirect.co.uk/referrer.asp?SKUNumber=102399&ReferrerCode=4
    To be honest, it doesn't look like it will fit the Viera as the bottom sticks out :rolleyes:
    It says virtually flush fitting, but you can't have that on the Vieras, help???
    Has anybody bought a viera of them with this mount?
  2. Jazz Monkey Jr
    Jazz Monkey Jr
    Jan 10, 2005
    14,242
    2
    4
    137
    Garstang, Lancs
    +1,625
    I have had an e-mail from RGB Dierct:
    Still not convinced
  3. Jazz Monkey Jr
    Jazz Monkey Jr
    Jan 10, 2005
    14,242
    2
    4
    137
    Garstang, Lancs
    +1,625
    Fitted perfect :thumbsup:
