Viera viewing modes
Discussion in 'Plasma TVs Forum' started by adrianl, Dec 17, 2004.
  1. adrianl
    adrianl
    Can anyone please enlighten me as to the nature of the different Cinema/Normal/Dynamic modes, and suitability for different sources/viewing environments?
    In past I'd assumed that (apart from Auto mode, which I understand uses sensor to adjust picture dynamically) were just names for different factory presets of the modes (eg Cinema for dak rooms = low brightness) but I'm not certain now. Picture looks different with similar contrats/brightness settings when you switch from say normal to dynamic. I realise the modes also change things like mpeg nr but is there more to it?
    The manual's cryptic on this point, but refers to all four modes featuring "automatic enhancement".
    Thanks for any advice or info,
    Adrian
  2. AVmaster
    AVmaster
    Dec 12, 2004
    381
    Liecestershire
    You're absolutely right
    Cinema = dark environment
    Normal = shoot anyone who doesn't know that one
    Dynamic = used for shop displays where it's REALLY bright
    and Auto = used to be known as CATS where it adjusts the viewing mode according to the lighting situation.
    I leave mine on Normal.
  3. Tejstar
    Tejstar
    Dec 4, 2002
    22,809
    London
    +1,082
    For the first 200 hours keep it in cinema mode!
  4. brackenlamb
    brackenlamb
    Oct 14, 2003
    421
    i put mine in normal from day 1 but had the levels on low
  5. blindlemon
    blindlemon
    The gamma setting for each mode is different (and possibly other things as well) - hence the differences between the same brightness/contrast for each mode.
  6. adrianl
    adrianl
    Thanks for that - I thought looking at the different images that it could be different gamma settings.
  7. THE BOARS
    THE BOARS
    Nov 25, 2004
    4,071
    68
    +86
    cinema mode for the first 200 hours why could u explain
  8. AVmaster
    AVmaster
    Dec 12, 2004
    381
    Liecestershire
    It's darker and therefore reduces the likelyhood of screenburn during the most crucial hours of use.
  9. GalacticaActual
    GalacticaActual
    Jun 1, 2004
    5,866
    Galactica C.I.C.
    +279
    I have noticed that even if all viewing modes have been adjusted using DVE ( Digital Video Essentials disc) that they still all give different results when viewing normal images(Not test paterens).
    Auto--- does exatctly what is ays on the tin, and inconjuction with the sensor on the fron of the Viera will adjust the brigtness and contrast depending on the rooms ambient light.
    Dynamic---- I belive is very close to the sony setting of LIVE that I used to have on my old television. It is designed to give ultra vivid images on broad casts of live sports and concerts.(its a good way of getting people to notice the plasma in the shop as well :D ) This mode however tend not to give this best overall colour even when adjusted.
    Cinema------seems very good once calibrated, however switching between this and normal mode reveals that the image is not as clear and sharp even if you move the sharpness option up.
    Normal------- is the mode i use as once adjusted seems to give the best overall image. :thumbsup:
    This is of course just my opinion and based on my eyes and viewing conditions.
  10. Steffche
    Steffche
    Don't you find though that normal doesn't have as good a range as far as greyscale is concerned? The darker (lower IRE) boxes look distorted, whereas cinema is much more even and smooth. Agreed that cinema is a little blurred even with sharpness cranked up. Dynamic can look pretty good too if you turn contrast all the way down...well almost all the way!
    What are you guys experiencing as far as color temp goes? Is warm TOO warm on your displays?
    And here's a real BIG QUESTION..........
    Can anyone post their factory setting for White Balance for 625i/p mode for normal and warm color temp???
    PLEASE!!!
  11. Funkybase
    Funkybase
    Jul 21, 2004
    69
    I've also noticed that the color balance and greyscale is good. But you need to lower the contrast to 4-5 % of the bar.
    Something really wierd happened the other night. Was watching normal tv mode (analog) and the PQ was absolutely stunning. Felt like there was more light in the picture... but now it's back to normal again. Thought for a while that the plasma where turn in some sort of safety mode for the first 500 hours... i've checked cabels. The thing was that this effected all inputs except for the component one. I had better pics on both analog and digital tv fed through the rgb... this is strange... :confused:
  12. GalacticaActual
    GalacticaActual
    Jun 1, 2004
    5,866
    Galactica C.I.C.
    +279
    Yep. When gordon came to calibrate my Plasma, he told me that cinema was more acurate for colour. However like has already been said cinema is a bit blurred.Its not enough to say that the image is out of focus though :confused: . I still find normal mode to be the one I preffer though , although Normal mode cant quite seem to deal with darker images like cinema can :confused:
    You know we could actually be over analising all this, perhaps we need to take a step back and enjoy the stuff we are watching. :D
  13. blindlemon
    blindlemon
    What, you mean you actually watch something other than DVE? :devil:
    Shame on you! :D
  14. GalacticaActual
    GalacticaActual
    Jun 1, 2004
    5,866
    Galactica C.I.C.
    +279
    :rotfl: :rotfl: :rotfl: :rotfl: :rotfl: ;)
  15. Steffche
    Steffche
    I know where you're coming from.......my wife leaves the room as soon as she hears the jet roar past in the opening scene!!!!
