viera sound delay on e55 pannasonic when watching sky
Discussion in 'Plasma TVs' started by brackenlamb, Oct 29, 2004.
  1. brackenlamb
    brackenlamb
    Oct 14, 2003
    421
    i have been watching sky + on my dvd recorder,and there seems to be an audio delay.
    i have sky + scart to dvd recorder
    component from dvd recoder to veira plasma
    optical out from dvd recorder to amp.
    not sure if this is correct ot i need something else.
    cheers in advance
  2. AV Junky
    AV Junky
    Oct 30, 2002
    1,209
    Cheshire, UK
    +68
    Nothing wrong with your set-up M8. Audio delay is one of those things that happens sometimes with digital display panels. The processing in the display can sometimes add a fraction of a second delay, leading to lip-synch failure.
    Some amps/receivers have a built-in audio delay function to deal with this problem. There's also a stand-alone device in the pipeline that will do the same thing.
  3. MAW
    MAW
    Jan 24, 2002
    14,082
    Nr Dorking
    +412
    See if you can set a delay on your amp, even just the centre channel will help. That's the one where most of the speech happens. Sometimes you can 'fool' it into delayng the centre channel by telling it the centre speaker is in your lap, ie set the distance to very close. Worth experimenting with this, lip sync is very distracting, I get it with my s-vhs recorder when routed through an iscan, which only delays digital audio.
  4. happyh
    happyh
    Aug 6, 2004
    309
    Northants Riviera
    I had the same problem with my "old" skybox, although I have it scarted to the viera not via the E55.
    I cured it by running another audio lead from the viera audio out to the amp tv audio in.
    Perfect.
    Suggest you try this, or better still a digital audio from the sky+ to the amp, then switch the amp between DVD and TV as you require.
    worked for me. :thumbsup:
