Viera + Sky Remote
Discussion in 'Plasma TVs Forum' started by Tejstar, Nov 14, 2004.
  1. Tejstar
    Tejstar
    Dec 4, 2002
    22,794
    London
    +1,080
    I've been setting up my new 37" Viera this weekend (loving it so far btw :) )and wanted to know whether there was a way that I can control the Viera's volume via the Sky remote like I have done on previous tv's?
    It's so much hassle changing the remote all the time - anyone have any ideas? :confused:
  2. moku
    moku
    Sep 19, 2004
    88
    Manchester
    You may have to contact Sky Customer Service to see whether they have a code for the Viera. I cannot swear on it, but I'm sure someone on this forum contacted Sky and was given a code which enabled the control of the Viera using the Sky remote.
  3. Tejstar
    Tejstar
    Dec 4, 2002
    22,794
    London
    +1,080
    OK Cheers, I'll try that! :smashin:
  4. rugbyboy14
    rugbyboy14
    Oct 12, 2004
    56
    look in the back of your sky instructions I used the code 0035 for my panny and it works fine. search the forums I have also posted detailed instructions on how to do it there too.
    steve
  5. Tejstar
    Tejstar
    Dec 4, 2002
    22,794
    London
    +1,080
    This is what I found by searching the forums but the code differs from above – will either work?
    press tv on sky remote
    hold red and select button for 2 seconds, (red light flashes twice)
    enter code 0051
    press standby
    plasma should switch off
    press select.
  6. Gagzi
    Gagzi
    Sep 10, 2004
    179
    +12
    There definately is a code for it as I control my Viera from the Sky Remote you may have to ask for it though. You can also access this information from the Services Menu on Sky I think.
  7. Tejstar
    Tejstar
    Dec 4, 2002
    22,794
    London
    +1,080
    The three digit code 678 worked for me!
    Here's the instructions fyi:
    1. Turn on your TV.
    2. Press tv on your Sky remote control.
    3. Hold down select and the red button together for about two seconds, until the red light on the Sky remote control blinks twice.
    4. Key in the three digits of the first 'Direct Set' code for the manufacturer of your TV; the red light on the Sky remote control will blink twice.
    5. Press tv and try the handset, using all the function buttons like power, volume and channel etc. If it works all the TV functions, then try the tv guide button.
    6. If the Direct set code did not work then start again from step 1 with the next three digit code in the list for the manufacturer of your TV.
    7. Press tv guide .
    If you see the TV Guide screen, the remote control setup process is complete.
    If you did not see the TV Guide, you must now set the TV Guide function as follows:
    8. Press tv on your Sky remote control.
    9. Hold down select and the green button together for about two seconds, until the red light on the Sky remote control blinks twice.
    10. Key in the number of the channel on your TV that you use for watching satellite TV (For scart switching, this may be one of the other buttons on your remote e.g. help, i or a colour button).
    11. Press select on your Sky remote control. The red light blinks twice. The remote control setup process is complete.
  8. GalacticaActual
    GalacticaActual
    Jun 1, 2004
    5,858
    Galactica C.I.C.
    +279
    If you look on sky active and then the customer services bit, ther are instructions on how to enter the codes into the remote. I found that the code for the panasonic pa20 worked with my panasonic viera. :thumbsup:
  9. dayjur1
    dayjur1
    Dec 11, 2004
    Yeah, the code 678 works with my Viera 37" plasma!
  10. dunbad
    dunbad
    678 code worked fine for me too :cool:
  11. PLASMABABBY
    PLASMABABBY
    Jul 2, 2004
    406
    Walsall
    +15
    Hi Tejstar,
    Have a look at http://www.hummer.co.uk/remote-setup.htm
    I have a fairly new Sky (not Sky+) remote and using the information on that site have configured my Sky remote to switch my Yamaha AV amp on and off and also to adjust the volume and use the mute button.
    So, provided that your Sky remote is a fairly recent one I think you should be able to get it to do the same with your Viera.
    Good luck
  12. hao
    hao
    There are several codes which can be found to work in the SKY services menu and if you go up a page it gives a shortened method of input. 678 is one of them but Iv'e tried them all as the remote works slightly differently with my Viera. Pressing TV and on, or a station button ,will get Freeview. Pressing Sky will switch to Sky but to get back to Freeview I must press TV followed by Help. The TV will switch off as normal but if I press Sky then off whilst watching it the screen makes a whineing sound which sounds very unhealthy. If I press select whilst watching freeview it freezes the picture although the sound keeps going. Has anyone else found these anomolies with the Sky remote?
  13. teewealthy
    teewealthy
    Thank you all, 678 it worked for me. panasonic viera
  14. tvbox
    tvbox
    Mar 23, 2009
    5,713
    Prestwich, Manchester
    +812
    WOW! This thread is more than 5 years old:rotfl:
  15. Cloudane
    Cloudane
    Apr 27, 2009
    4
    Ha, very old thread.
    0678 working fine here on a new X10. Couple of things,
    a) Any way to enable the arrow keys? I noticed that 'help' brings up AV input selection and 'play' brings up the aspect selection - very useful! But as the arrows don't work, they're actually not useful at all :D
    b) Possible to stop the TV button from switching the input from RGB to 'fuzzy' video mode?
  16. Miss Chief
    Miss Chief
    Jun 12, 2007
    7,823
    +1,187
    The arrow keys don't work I'm afraid but each press of the help key will cycle through the inputs.
  17. Cloudane
    Cloudane
    Apr 27, 2009
    4
    Thanks Skytech, never thought of that. Duh. :)
  18. Die_hard
    Die_hard
    Jan 20, 2008
    22
    3
    Stockport
    Another successful 0678 code here :D
  19. 3000gto
    3000gto
    Jan 18, 2006
    1,139
    Edinburgh
    +102
    0678 works on g15's too :smashin::smashin:
  20. flame69
    flame69
    Mar 5, 2012
    0678 worked for me too on my Panasonic VIERA TX-P42S30B 42" Plasma.
    Thanks to those who posted it :smashin:
  21. patwestlake
    patwestlake
    Jan 27, 2003
    129
    Cardiff
    +6
    678 works fine for the new L32E5B with either rev 9F or rev6 remotes
    Pat
