Viera Progressive de-interlacer?
Discussion in 'Plasma TVs Forum' started by reklor, Mar 1, 2005.
  1. reklor
    reklor
    Nov 24, 2004
    5,290
    Huntingdon
    +225
    Hi folks. I understand the Viera range of Plasmas are Prog scan. If you feed it a DVD signal via component (with the dvd player set to progressive)......is that all you need to do? Or can you switch the prog on/off on the plasma?
    Any help would be GREAT :thumbsup:
  2. GalacticaActual
    GalacticaActual
    Jun 1, 2004
    6,123
    Galactica C.I.C.
    +350
    The plasma will detect an incoming progressive signal from the dvd player and display it as is. You will turn it on and off from the dvd player. I am pretty sure that there is no option in the standard user menu on the Viera to turn of an incoming progresive signal.
    With progresive scan the plasma will auto switch to wide mode,so if the source material you are watching is not anamorphic it will stretch the picture.
  3. reklor
    reklor
    Nov 24, 2004
    5,290
    Huntingdon
    +225
    cheers mate, very helpful. I thought that was the case but after reading a few posts on the dvd forum i thought it was possible to have one or the other (prog scan from the dvd player and not the tv and vice versa).
  4. Gordon @ Convergent AV
    Jul 13, 2000
    14,245
    +3,110
    All fixed pixel devices have video processing built in and work in a progressive mode(lets forget alis plasma right now). The Vierra is a progressive display just like all it's competitors are as well. You cannot turn off its ability to display images progressively. The ability to choose whether it does the de-interlacing to progressive comes if you send it an interlaced signal or a progressive one. If it's progressive it just scles things to fit pixels and if you send it interlaced it de-interlaces then scales to ft pixels....ths is pretty much what David was explaining...
    Gordon
  5. GalacticaActual
    GalacticaActual
    Jun 1, 2004
    6,123
    Galactica C.I.C.
    +350
    Gordon, would you agree that the picture is better for handerling straight lines and Jaggies if you use a progresive signal from the dvd player? I think this was the conclusion we came to when we tried on mine, using your startrek inserection disc, wasnt it?
  6. Gordon @ Convergent AV
    Jul 13, 2000
    14,245
    +3,110
    I think I used Insurrection to show you what film detection is....not sure...I would suggest that prog scan from most dvd players is likely to be the best solution jus tnow though.
    Gordon
  7. GalacticaActual
    GalacticaActual
    Jun 1, 2004
    6,123
    Galactica C.I.C.
    +350
    Yes, thats right, but the Viera was not showing a progresive image when feed a standard signal from the dvd player, was it?
    I know that the straight lines were totaly clenaed up when progresive was swithced on and the jaggies all but disaperaed, but when it was a standard signal it was a lot worse. :)
  8. Gordon @ Convergent AV
    Jul 13, 2000
    14,245
    +3,110
    The plasma is ALWAYS displaying a progressive image. It cannot do anything else. All that is changing is where the conversion from interlaced to progressive takes place. In this case the DVD player was better than the plasma.
    Gordon
  9. GalacticaActual
    GalacticaActual
    Jun 1, 2004
    6,123
    Galactica C.I.C.
    +350
    Ah, now you see that is why you are the expert in such matters. Thanks for clearing that up. ;) :smashin:
  10. Selectortone
    Selectortone
    Nov 18, 2002
    70
    Very interesting thread.
    In a previous thread the concencus seemed to be that the progressive output from the average DVD player/recorder (in my case a Panasonic DMR-E55) would be inferior to the progressive processing performed on an interlaced output from the same player by the panel's electronics (a PWD7) - on the basis that the electronics in a £200 DVD player are likely to be inferior to the electronics in a £1.5k plasma panel.
    I'd love to hear some more comments from the experts on this.
  11. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
    tis true you can quite easily tab between Prog and interlaced output so check for your self (low end DVDR i would stick to interlaced) David Which DVD player do you have?
  12. philthyanimal
    philthyanimal
    Sorry to butt in, i posted this last week and got no reply.
    Which would be better Prog from a 757ai or interlaced and let the PW7 do the de interlacing?
  13. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
    try it yourself and see its not hard to flick the buton
