Viera: new DVB services on every switch on
cpicking
Every single time I switch on my 32LZD85 I get a message that "New DVB services have been found. Press OK to scan" (or very similar words). It doesn't matter if I press ok, and let it go through a scan, or if I press 'Exit' and skip it - the next time, and every time, it tells me the same all over again. This is getting really irritating. Does anyone know how to stop it??
Thank you!
Caroline.
Blake77
Go : Menu, Set Up Menu, DVB Tuning Menu, New Service Message (set it to OFF). This is the way I have it set up on mine to avoid the same problem. I manually update channels about once a month to store changes.
cpicking
Thanks for your help. I actually stumbled on an answer by accident. If you re-run the initial channel setup, it sorts itself out. Problem has now gone away!
Caroline
