Viera n Progressive.
Discussion in 'Plasma TVs Forum' started by Anthall, Nov 3, 2004.
  1. Anthall
    Anthall
    Oct 27, 2004
    220
    Kettering
    +4
    Quick one which i know most of you will know the answer too.
    When watching a dvd with progressive scan and the dvd isn't
    a widescreen, i cant change the aspect ratio to 16:9. Do i need
    to use a function to stretch the image manually? Also i think
    im watching in progressive scan, i.e video set to progressive,
    component leads set up, but cant see any options to turn
    it on on the plasma. I would imagine i jist picks the signal up automaticaly?
    P.s. So dam pleased with the 42" Viera, Set all my contrast, brightess
    etc to about 30% of a full bar for a month, then jack em up to a
    comfortable 40-45%. :cool:
    Now im jabbering, so if someone could answer my above question, then cheers.
  2. Starky
    Starky
    Aug 31, 2004
    46
    Hi Ant., you've got to take it off the component setting (AV4C) to be able to switch aspect, hpe this helps. Happy viewing. :thumbsup:
