Viera LCD's finally in stores...
Discussion in 'LCD & LED LCD TVs Forum' started by cerebros, May 15, 2004.
Tags:
  1. cerebros
    cerebros
    Dec 27, 2002
    1,294
    48
    Leicester
    +29
    The new Viera LCD's have finally reached my local Shop @ Panasonic.
    Have to say that I mus have been half asleep when I saw pictures of them before, because I'd assumed that the speakers either side of the screen were detachable, whereas in fact they're part of the unit, which I think looks a bit crap like that.
    Couldn't form much of an opinion as it was only a quick look. They'd got the 28" running Finding Nemo DVD - which appeared to be filling the whole screen, so considering it's a 15:9 panel, it either crops off the left & right edges, or the store staff had it on some zoom mode to fill the entire screen.
    The 32" was showing The Hits as a widscreen image, so I'm not sure if this was a zoomed in image or if it's off Sky, because AFAIAA The Hits is 4:3 on Freeview.
    As I say, was only a brief look, so couldn't really comment on picture performance, but subjectively, the picture on the 32" seemed to be at least on a par with the 42" Viera plasma on the opposite wall that was also showing The Hits (admittedly, probably not the best test material).
