Viera DVB system update problem
Discussion in 'Plasma TVs Forum' started by lazzer, Sep 15, 2004.
  1. lazzer
    lazzer
    Hi Everyone,
    Each time I switch on my Viera 42 plasma I get a message saying that DVB update E10_2.36 is available,but when I press OK to update and get the "calculating duration" box it doesn't go any further.
    Have gone into the DVB menu system to check if it's up to date and it says it is but there is a different number.
    Could anyone please shed any light? It's getting a little annoying to get the update availble message everytime I switch on.
    Thanks in advance :)
  2. killabeez
    killabeez
    Jun 29, 2004
    67
    You have to make sure you are on a BBC channel to get the update to download,
    Dont switch channels whilst it does this,
    Hope this helps
  3. lazzer
    lazzer
    Thanks Killa, will certainly try this asap!
  4. Steve_P
    Steve_P
    Jul 3, 2004
    1,338
    67
    +142
    Following on from the advice above, the following quote was taken from the Panny website a year or so ago and is relevant to their TUCT20 Freeview box, I assume the same applies to your DVB tuner in your PE30.
    *EDIT* I have the whole page of the FAQ if you really want it but I'm guessing you will pretty much know the rest of it.
    S.
  5. lazzer
    lazzer
    Thanks Guys, got it sorted now, worked like a charm! :smashin:
