Viera and Panasonic DMR HS2.. Advice Needed
Discussion in 'Panasonic TVs Forum' started by seany57, Oct 14, 2004.
  1. seany57
    seany57
    :lease:
    Can anyone advise ont he best set up for my new Viera (TH42PE30) that will be arrving some time next week.
    I have Sky + and a Panasonic DMR-HS2 DVD Recorder. Reading previous threads the idea connection for the DVD is Component, but the HS2 does not have the component connections.
    I am also getting a DMR-E55 a part of the JL package
    What config and connections would give me the best output. I love the HS2 and all the flexibilty it gives me with the HD etc, so would like to keep using this with the new Viera, but then I want the best possible DVD picture which looks like it needs to be component.
    Any advice woudld be gratefully recieved.
    Sean
  2. MAW
    MAW
    Jan 24, 2002
    14,082
    Nr Dorking
    +411
    RGB scart will be fine. Get a good scart cable, and make sure you have enabled RGB on the HS2
