Viera Analogue Tuning Problems
Discussion in 'Plasma TVs Forum' started by dooid, Dec 13, 2004.
  1. dooid
    dooid
    I have a Panny Viera th42pe30. Everything is going great except I don't seem to be able to get the same channels that I got with my older sony crt. I only have analogue tv coming through and I can only get some tv channels. I have tried manually tuning but that hasn't helped. I have a few ideas about whats up but I was wondering if anyone else out there had a similar problem and how they fixed it. Cheers
  2. blindlemon
    blindlemon
    Get a better aerial :)
  3. sunil1234
    sunil1234
    Dec 5, 2004
    1,328
    48
    +121
    try an arial booster from Argos (if it doesnt work, take it back within the MBG period).
    I found it meant the difference between getting NO freeview channels to getting all of them at signal quality 7-9 across the board on my flats communal arial (yes i know it also amplifies noise but gettting nothing compared to everything makes all the difference!)
    (wife wont let me get sky YET as i have started her off on a 28"crt convincing her that a Panny 26" LCD was a better buy and then swapping for a 32 LCD due to JL in store pricing and now a 37" Viera plasma due to dead pixels on the LCD and a current JL promotion.
    S
  4. dshtt
    dshtt
    Dec 20, 2003
    120
    +4
    Further to my recent post can you confirm whether the Viera sets have an analogue tuner as well as dvb
  5. blindlemon
    blindlemon
